Author Topic: headlight low beam dont work  (Read 1342 times)
clitheroeguy
« on: March 27, 2011, 06:52:12 PM »
2005 model
just checked the lights and low beam doesnt work but high beam does and all other lights work aswell
what could be wrong
only thing i can guess which i going to try tomorrow is
check connection and if same then change bulb and if same my last option is changing fuse and check wires
but if they all fail im guessing my switch is knacked
anyone had this problem before
« Last Edit: March 27, 2011, 07:09:23 PM by clitheroeguy »
sidthesloth
  • Kymco ZX50
re: looking for help, please! having bogging issues with zx50
« Reply #1 on: March 27, 2011, 08:21:01 PM »
Does it have high and low beam? A lot of 50cc scoots don't have high beam. It would more than likely be the bulb.
clitheroeguy
Re: headlight low beam dont work
« Reply #2 on: March 28, 2011, 04:37:16 AM »
well when i use right side switch side lights work if i click on full theres nothing and if i press left side switch high beam or passing they both work but i dont want to be pulled leaving it on full beam and most likly will burn out the bulb faster
is there a chance the right side switch faulty if the left side passing switch works as that uses it as a low beam doesnt it
clitheroeguy
« Reply #3 on: March 28, 2011, 08:00:27 AM »
just took the headlight out but problem the lens wouldnt budge its like held on by sealent could i use a hairdryer would that not work
« Last Edit: March 28, 2011, 08:12:40 AM by clitheroeguy »
sidthesloth
  • Kymco ZX50
« Reply #4 on: March 28, 2011, 08:34:23 AM »
You shouldn't have to remove the lens, the globe goes in from behind, just remove the spring clip and the globe comes out.
clitheroeguy
« Reply #5 on: March 28, 2011, 10:15:41 AM »
yep done it working now thank god
