Author Topic: scooter revs but doesnt move  (Read 12204 times)
kymco God
« on: April 09, 2011, 09:32:47 AM »
the subject says it all, got any idea whats wrong with it?
cheers guys
ts1
Re: scooter revs but doesnt move
« Reply #1 on: April 09, 2011, 11:07:11 AM »
Remove vario cover, check the belt and then the clutch.
kymco God
« Reply #2 on: April 09, 2011, 11:10:58 AM »
cheers
kymco God
« Reply #3 on: April 09, 2011, 07:02:05 PM »
i have tryed that but still the same, every thing in that area is fine and works correctly, got anyother suggestions?
cheers
ts1
« Reply #4 on: April 09, 2011, 08:13:07 PM »
With the scooter on main stand, removed vario cover and engine running you should see the rear wheel spinning - or why not.
May be it seems to work fine trying on center stand, but there is not enough force tranferred to the rear wheel for real driving/acceleration. Clutch slipping or engine weak.
TechGuy
« Reply #5 on: April 10, 2011, 01:02:17 AM »
KG,
When you removed the CVT cover and started the bike... and rev'd the engine... What did you see?
Whisper
« Reply #6 on: April 11, 2011, 02:43:59 PM »
LOL!  If everything was fine it would work.  ;D
Here's what we need to know:
On the centerstand, with the Variator cover off, and the engine revving:
- Does the front pulley move?
- Is the belt moving?
- Is the rear pulley moving?
- Is the rear tire moving?
From there, we can point you in the right direction!
kymco God
« Reply #7 on: April 12, 2011, 03:18:05 PM »
cheers for all the replys, and yes all of that is working...it is hard to explain over this forum without you seeing it, but when i pull the throttle all the way back, it revs but only moves a little, then it will just pick up again, sounds like something is slipping?
cheers guys
Hoolander2
« Reply #8 on: April 13, 2011, 03:02:53 AM »
I'd take the clutch off and look for worn out pads or binding pivot points on the pads.  The other thing to do is a compression check on the engine.  As ts1 said, it would seem to be either in the clutch or else a weak engine.
Whisper
« Reply #9 on: April 13, 2011, 01:28:14 PM »
Best Case:  Clutch problems - Take it off and make sure everything moves as it should.  This would be my current bet.
Worst Case:  Your differential is destroyed - With the variator cover off, and the motor off, rotate the back tire by hand.  What does the rear pulley do?
juice
« Reply #10 on: April 13, 2011, 04:18:03 PM »
In one of K God's previous posts he was having trouble with the rear brake . Is it possible that he may have over adjusted the rear brakes resulting in the rear wheel not turning when the motor is reved ? Good luck .
kymco God
« Reply #11 on: April 13, 2011, 04:53:19 PM »
there is no play in the crank, it is all fine down in that dipartment, and i have new clutch pads on...lol got no idea what to do
thanks for your help :)
kymco God
« Reply #12 on: April 13, 2011, 05:14:47 PM »
when it is on the3 center stand and i rev it, the rear wheel moves completely fine
sparko
« Reply #13 on: April 13, 2011, 11:32:17 PM »
possibly the rollers stuck inside the variator and not pushing the variator sides together? I don't think you mentioned whether or not the variator was moving in and out with the belt moving to the outside diameter of the variator. :-\
