Author Topic: valve clearance  (Read 3140 times)
dudley
valve clearance
« on: April 11, 2011, 03:51:19 PM »
what are the clearances per manufacturer.
i set mine to .004 inches in and out, but some people have suggested .005 out?
2010 super 8 150  red/black
bought march 2011
4000 miles march 2012
dr pulley variator w/stock weights
top speed 61.5mph  gps verified
Portland Steve
Re: valve clearance
« Reply #1 on: April 11, 2011, 10:36:34 PM »
Does it run well the way that you have it?
Did it make any difference in how it runs after you adjusted the clearance?
It sounds like you are within tolerance with either.
Amaro321
Re: valve clearance
« Reply #2 on: October 21, 2016, 03:55:54 PM »
I wonder if you found a difference between the two settings
Mr. Paul
Re: valve clearance
« Reply #3 on: October 21, 2016, 05:18:57 PM »
I set my People 150 at .004 in and out. Dont think it would hurt to set the exhaust at .005 if you want. I just go with what the specs call for.
2009 Kymco People 150
1993 Honda Helix
Amaro321
Re: valve clearance
« Reply #4 on: October 22, 2016, 01:21:46 AM »
Thanks! I just finished setting mine and test road it. Runs like a top. They are at.004 ish... It back fired twice at first, then rode normal
wkreps
Re: valve clearance
« Reply #5 on: November 29, 2016, 03:09:26 PM »
I adjusted to .004"
Videos
part 1
part 2
part 3
Wayne
Re: valve clearance
« Reply #6 on: January 12, 2017, 06:32:04 PM »
I just checked my valves after 7500 miles since the last check.  I know it's supposed to be done every 2500 miles but I'm Lazy.  The exhaust valve hadn't changed but the intake had loosened up slightly so I adjusted it.  I also replaced the spark plug.  The old one looked fine but I replaced it anyway.  25,500 miles on my Super 8 now.  BTW I left my Exhaust at .005 because I prefer to be in spec or slightly loose.
