Author Topic: Recommended maintenance schedule  (Read 5432 times)
Yager200i
« on: April 13, 2011, 06:22:18 AM »
The following was taken from the Kymco Dink 200 service manual (page 3-2). The Dink 200 is the carbureted version of our Yager GT 200i.
I = Inspect, Clean, Adjust, Lubricate or Replace as necessary
A = Adjust
C = Clean
R = Replace
T = Tighten
Recommended maintenance schedule:
(for new bikes)
300 km (186 miles):
R - engine oil & filter
R - gear oil
(over 12000 km start over here)
1000 km (621 miles):
R - gear oil
I - air filter
I - brake system
I - steering head bearing
2000 km (1242 miles):
A - valve clearance
I - brake system
3000 km (1864 miles):
I - brake system
C - spark plug (R - if necessary)
4000 km (2485 miles):
C - engine oil filter screen
A - valve clearance
I - brake system
I - suspension
I - tires
5000 km (3106 miles):
R - gear oil
R - air filter
I - brake system
I - brake levers
I - brake shoe wear
I - shock absorbers
6000 km (3728 miles):
I - brake system
I - radiator core
I - radiator cap
7000 km (4349 miles):
I - brake system
8000 km (4970 miles):
A - valve clearance
I - brake system
I - drive belt
I - suspension
T - nuts/bolts/fasteners
I - tires
9000 km (5592 miles):
I - brake system
10000 km (6213 miles):
R - fuel filter
R - gear oil
R - air cleaner
R - radiator coolant
I - brake system
I - brake levers
I - brake shoe wear
I - shock absorbers
11000 km (6835 miles):
I - brake system
12000 km (7456 miles):
A - valve clearance
I - brake system
I - suspension
I - tires
I - radiator core
I - radiator cap
For higher odometer readings, repeat at the frequency interval established here.
Service more frequently when riding in dusty or rainy environs, or when riding mainly at full throttle.
This breaks down to the following schedule:
Engine oil & filter - first replace at 300 km (186 miles), then replace at 1000 km (621 miles), then replace at 1000 km (621 miles) intervals.
Engine oil filter screen - clean at 4000 km (2485 miles) intervals.
Fuel filter - replace at 10000 km (6213 miles) intervals.
Gear oil - first replace at 300 km (186 miles), then replace at 1000 km (621 miles), then replace at 5000 km (3106 miles), then replace at 5000 km (3106 miles) intervals.
Valve clearance - first adjust at 2000 km (1242 miles), then adjust at 4000 km (2485 miles), then adjust at 4000 km (2485 miles) intervals.
Air cleaner - first inspect at 1000 km (621 miles), then replace at 5000 km (3106 miles), then replace at 5000 km (3106 miles) intervals.
Spark plug - clean at 3000 km (1864 miles) intervals, replace as necessary.
Brake system - inspect at 1000 km (621 miles) intervals.
Drive belt - inspect at 8000 km (4970 miles) intervals, replace as necessary.
Suspension - inspect at 4000 km (2485 miles) intervals.
Nuts/bolts/fasteners - tighten at 8000 km (4970 miles) intervals.
Tires - inspect at 4000 km (2485 miles) intervals, replace as necessary.
Steering head bearing - first inspect at 1000 km (621 miles), then inspect at 6000 km (3728 miles), then inspect at 8000 km (4970 miles), then inspect at 4000 km (2485 miles) intervals.
Brake fluid - inspect during daily pre-ride inspection, replace at 12000 km (7456 miles) intervals.
Radiator coolant - replace annually or at 10000 km (6213 miles) intervals.
Radiator core - inspect at 6000 km (3728 miles) intervals.
Radiator cap - inspect at 6000 km (3728 miles) intervals.
Brake levers - inspect at 5000 km (3106 miles) intervals.
Brake shoes - inspect at 5000 km (3106 miles) intervals, replace as necessary.
Shock absorbers - inspect at 5000 km (3106 miles) intervals.
Yager200i
Re: Recommended maintenance schedule
« Reply #1 on: April 13, 2011, 06:45:11 AM »
MY MAINTENANCE SCHEDULE:
Brake system - inspect at 600 mile intervals.
Engine oil & filter - replace at 50 miles, 100 miles, 200 miles, 400 miles, 800 miles, then at 600 mile intervals.
Engine oil filter screen - clean during each engine oil change.
Gear oil - replace during each engine oil change.
Spark plug - clean at 1500 mile intervals, replace as necessary.
Valve clearance - adjust at 200 miles, 400 miles, 800 miles, 1600 miles, 3200 miles, then at 2000 mile intervals.
Suspension - inspect at 2000 mile intervals.
Tires - inspect at 2000 mile intervals, replace as necessary.
Steering head bearing - first inspect at 500 miles, then inspect at 2000 mile intervals.
Air cleaner - inspect at 500 miles, then replace at 2500 miles intervals.
Fuel filter - replace at 3000 mile intervals.
Brake levers - inspect at 3000 mile intervals.
Brake shoes - inspect at 3000 mile intervals, replace as necessary.
Shock absorbers - inspect at 3000 mile intervals.
Radiator core - inspect at 3500 mile intervals.
Radiator cap - inspect at 3500 mile intervals.
Drive belt - inspect at 4000 mile intervals, replace as necessary.
Nuts/bolts/fasteners - tighten at 4000 mile intervals.
Radiator coolant - replace annually or at 6000 mile intervals, whichever comes first.
Brake fluid - inspect during daily pre-ride inspection, replace at 7000 mile intervals.
axy
« Reply #2 on: April 13, 2011, 08:27:52 AM »
 ;D :o ??? :P
Kymco Agility 125 2008
