Author Topic: Coil/electric question  (Read 1281 times)
kcjoe
« on: April 18, 2011, 04:57:42 PM »
I replaced my ignition coil after getting 20 ohms on the resistance per analogue multimeter.  After replacement it remains around 20.  Is the problem in the CDI unit?
Shaka
Re: Coil/electric question
« Reply #1 on: April 18, 2011, 06:57:51 PM »
Where are you getting the 20 ohm reading?  Did you replace the cap/boot also?
kcjoe
« Reply #2 on: April 18, 2011, 07:14:43 PM »
Sorry.  I rechecked it just now (2:12 pm cst) and got 1 from prong to prong on the coil and 8 from sparkplug cap to either prong on the coil.  Also, I checked the fuel.  I disconnected the line at the carburetor and cranked a few times; but no fuel.  Does that sound right?  I had excellent from the tank to the filter/pump.
Shaka
« Reply #3 on: April 18, 2011, 07:20:38 PM »
Your coil should be good then.  Unhook your vacuum line and suck on it to see if any fuel comes out the other line.
kcjoe
« Reply #4 on: April 18, 2011, 08:08:52 PM »
Fuel ran out of the line from the filter/pump.  I cleaned the carburetor and hooked it back up.  I didn't see any broken pieces or chunks of dirt.  Do I need to prime the carburetor?
This honey died on me at a stoplight.  I had been adjusting the idle/air earlier, but it had always started.  I replaced the sparkplug.
Shaka
« Reply #5 on: April 18, 2011, 09:47:02 PM »
You can prime the carb by sucking on the vacuum line.  That will fill the bowl, otherwise it should do on it's own after cranking for a few.
kcjoe
« Reply #6 on: April 20, 2011, 12:32:22 PM »
Sorry, I got busy with my job.  I tried to start it until I had to re-charge the battery.  It still doesn't sound like it is getting a spark.  I rechecked the gap on the sparkplug and adjusted the idle and air on the carburetor slightly - each one 1/2 turn at a time.  Is there some other way it would just cut off?  When the kill switch is engaged - doesn't that cut off the electricity?
bniesen
« Reply #7 on: April 25, 2011, 07:11:13 PM »
sounds like the same problem I had when I got the scoot out of storage. I did the same thing you did with taking the carb off and just clearing out the jets. It took a long time of kicking before it started, seriously like a straight minute of constant kicking to get it to start. I would try changing the spark plug and just keep trying to kick start it. I would have to kick it like 10 times in a row before it would start, but now I replaced my battery so I don't have to kick start it any more (at least for a while anyway).
Good luck.
