Author Topic: 2007 Agility 125 Problems  (Read 1147 times)
davis5663
« on: April 20, 2011, 10:30:26 PM »
Have Agility 1try25 purchased new, keep it maintained. Parked it for 2 months, was running fine when I shut it off. When trying to restart, the would try to start and then die. The local dealer cannot figure it out. In the past the issues have been carburator or the electronic box whatever that is. Not sure what to do now. The local dealer has indicated that they everything they know, new fuel, new kill switch. He thinks it is electronic.
How to diagnose this problem. Was thinking of using fuel can and bypass fuel tank? Can the electrical be unplugged, use manual kick starta and see if it is the electical wiring harness which dealer was ready to install next. I like the dealer. Some other issues that these 125's have had? Thanks for any help.
TechGuy
Re: 2007 Agility 125 Problems
« Reply #1 on: April 21, 2011, 01:04:55 AM »
Did you try cleaning the carb and changing the fuel?  Ethanol separates within 60 days into a sludge to plugs the carb.
marioG
« Reply #2 on: April 25, 2011, 04:56:56 AM »
ive got 2008 agility, and its run all over the winter (-2deg cel)..
seems too me that problem could be pickup coil...like me...
try to dismantle and push pickup coil to rotor catch in the middle...works for me---
after i dismantle hole carb....this helped me....bloody china...thing :-\
FUBAR is an acronym that commonly means "f***ed up beyond all recognition/any repair".
mjcharger
« Reply #3 on: April 25, 2011, 09:25:21 PM »
First off can you tell us if your scooter is producing a continuous spark?
You need the CDI box connected in order for the scooter to run.
When my CDI failed, my scooter wouldn't produce a spark, or it would produce a spark when I flipped the killswitch up and down. It would spark once and then die. I talked to a few people and they said the CDI. Once I did that the scooter started up first try and has ran like a champ.
