Author Topic: Idle screw  (Read 845 times)
Loomin
Idle screw
« on: April 25, 2011, 12:12:50 PM »
In the manual it says:
CARBURETOR IDLE SPEED
Remove the inspection cover. Warm up the engine before this operation. Start the engine and connect a tachometer. Turn the throttle stop screw to obtain the specified idle speed.
Idle Speed: 1900  (plus or minus 100rpm)
Where do I attach the tach?
Shaka
Re: Idle screw
« Reply #1 on: April 25, 2011, 03:07:37 PM »
That refers to an inductive tachometer which has a pickup that goes around the spark plug wire.  It senses when the pulse runs through the spark plug wire and breaks the electromagnetic field created by the pickup.
