Author Topic: Sting/Yup 50 won't start  (Read 1181 times)
macocoy
  • Sting/yup 50 2 stroke(2009)
« on: May 06, 2011, 06:04:03 AM »
I recently ordered a tecnigas next r for my bike,I put it on and went for 1 mile of test run,felt like losing power at WOT ,.I knew I had to upjet anyway,came home and upjet my main  to #90 from #72.I put everything back together and as I start the scoot ,It won't start .checked and replace sparkplug,siphoned gas replace with fresh one,cleaned carb and still would start...Now I'm thinking did I damage the piston in that one mile of test run?(mostly half throttle).Any advise would be appreciated.......
Scooters r big boys toys-
Tecnigas next r,malossi variator,1000 clutch torque spring,Uni open air,
macocoy
Re: Sting/Yup 50 won't start
« Reply #1 on: May 07, 2011, 10:30:09 AM »
Finally got my sting started,thanks for Peters advice.
Basically if you drained gas out of carb from jetting/cleaning,and when you put it back together and your bike doesn't start,give it couple of kickstart (up to 20) to fill up carb with gas,holding throttle 1/4 open,just be careful not to flood engine,if you think you flooded engine wait awhile before trying again.Don't Panic like I did(lol)
