Author Topic: Kymco Super 8 50CC 4stroke modification (need for speed)  (Read 11397 times)
AKL_HBG
  • 2016 Super 8 50x
Re: Kymco Super 8 50CC 4stroke modification (need for speed)
« Reply #15 on: May 17, 2018, 10:22:05 AM »
Ianmac,
I just found this thread.  I just purchased a 2016 Super8 50x.  I purchased a few racing and unrestricted CDI's and they all made my scooter run worse.
It appears I have the same CDI.  Which specific wire did you cut as I also have two wires that are purple/pink combination.  Did you just cut one wire or two?
Thanks for your help.....
AylmerFreerider
« Reply #16 on: May 21, 2018, 12:21:59 AM »
don't cut the wire just slip it out of the harness and cover it with electrical tape.
It was the purple one.
I have the the 2015 version and the issue is that it is a 4 stroke.  2 strokes have way more power.
There is a washer in the manifold that can be removed as well.  It will allow more fuel to pass.
The only other option for more speed and a 70cc upgrade kit and new rear gear.
Hope this helps.  I am about to do the 70cc kit on mine.
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
Technigas Silent Pro Exhaust
3 x 1" Air Filter additions to Air Box
AKL_HBG
  • 2016 Super 8 50x
« Reply #17 on: May 21, 2018, 12:35:23 AM »
There are two purple wires.  Which one should I slip out?  Thanks for your help!
