Author Topic: Problem With Gauges  (Read 1803 times)
hondapete
Problem With Gauges
« on: May 09, 2011, 04:11:34 AM »
Gauges Flashes On & Off!!  No Readable Letters Or Numbers. Are There Any Reset For Gauges??
Sat For About A Month
MaryK
Re: Problem With Gauges
« Reply #1 on: May 09, 2011, 04:05:04 PM »
Sitting for a month should not cause any problem,
but the battery may be discharged.  Measure the battery voltage.   It should be 12.5 volts DC.
If lower voltage but still about 12 volts, you can charge the battery with a trickle charger (no more than 1 amp) and it will take about 5 hrs.
If less than 12 volts, take the battery to an auto parts store for testing under load to see if it is any good.
I hope this helps.
New Rider in 2010
2009 GrandVista 250
hondapete
« Reply #2 on: May 10, 2011, 06:03:36 AM »
Charged Battery, Still Flashes On & Off.
hondapete
« Reply #3 on: May 11, 2011, 02:18:36 AM »
 Tried Tonight, Everything Working!!! Gauges Are Fine.  Learned From Kymco Dealer It Could Be A Moisture Problem, ( Grarage Flooded- Not Bad Water On Floor) Covered Bike W/Fan Blowing  GREAT!!!  Problem Hopefully Gone.  GONING RIDING!!!!
