Author Topic: Ingition Switch wiring  (Read 887 times)
Dale Genther
« on: May 15, 2011, 10:14:55 PM »
Somebody gave me a 2006 Agility 50. There is no key or manual with it. It has not been run in a least two years. Before I invest in a new ignition switch and battery I want to see if it will start. To do this I need to simulate the operation of the ignition switch using jumper wires. The current switch has five wires coming off of it. A red, a black, two green and one black with white tracer. The red, black, and green go to a six position white plastic connector, of which only four are used. The black with white does not go to this connector, but to a separate plug. This separate female plug that this black/white wire plugs into has a blue wire with yallow tracer on it. I have a battery I'm going to take out of another scooter I have to power this test.
Also, is ther anything else I should do besides changing the fuel and checking the oil?
Re: Ingition Switch wiring
« Reply #1 on: May 15, 2011, 11:02:04 PM »
If the scoot sat to long you may have to clean the carb out. and as far as a key you might beable to try any gy6 ignition switch if you can find a used one that might help ya. most of theam are all plug ins.and easy to do. I would spend some time cleaning everything air filter new gas filter fresh gas fresh oil and maybe gear oil.
