Author Topic: FORK RETAINER HEX?  (Read 860 times)
stuh7
FORK RETAINER HEX?
« on: May 17, 2011, 06:11:29 AM »
hi there can any one tell me what size the fork retainer hex is? (the one in the inside of the fork that stops the piston coming out of the cylinder) as i need to go out and bye one long enough so i can seperate the fork and then chop it.
cheers
stuart
I may be small but look how far i will go!!!
thebatman
Re: FORK RETAINER HEX?
« Reply #1 on: May 17, 2011, 11:22:34 AM »
I am having the same issue.. it's pretty big... :D
A tip was given to me...... take a bolt and stick inside there and use vise grips to loosen the nut. That'll give you a homemade allen wrench to the correct size, THEN you can take the real nut with you and get the correct allen wrench...... Hope this helps.....Keep us posted... ;)
"THE BAT"MAN...
Says:
stuh7
« Reply #2 on: May 18, 2011, 06:39:54 AM »
Cheers mate took me 3 times of reading to get it :) i'm not the sharpest!!
so tonight im in the garage sorting my bolts out :)
sidthesloth
  • Kymco ZX50
« Reply #3 on: May 18, 2011, 09:54:27 AM »
Buy a set of inhex sockets. Very handy down the track when you want a large allen key, that you just don't have. I don't use mine very often, but I am glad I have them when I need them.
