Author Topic: Kymco Super 8 150 just barely idles and will not accelerate  (Read 1316 times)
andrito
Had no spark, found a shorted wire on the pulser coil, now the bike will idle for a few seconds and then die.  Dies instantly if you try to increase speed with the throtle.  Do I have a spark problem or fuel problem?  Any suggestions would be appreciated.
andrito
Re: Kymco Super 8 150 just barely idles and will not accelerate
« Reply #1 on: May 18, 2011, 10:16:25 AM »
Turned out to be an easy fix.  Adjusted the mixture screw on the carburetor and that solved the problem.
