Author Topic: GPS mount for GV250  (Read 3280 times)
allenquach
GPS mount for GV250
« on: May 18, 2011, 06:23:19 AM »
I just finished mounting a gps on GV250. You just buy a mount from  www.gpscity.com (cheaper and fast shipping) via www.ram-mount.com (more expensive). My specific GPS is Garmin nuvi 1450LMT or just 1450 model. Here is the links to customize my mount for reference.
Motorcycle Brake Clutch Reservoir Cover Center Mount
http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045049056050085/Default.aspx
RAM EZY-MOUNT QUICK RELEASE ADAPTER SYST
http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065080045051050054/Default.aspx
RAM Cradle Holder for the Garmin nuvi 1440, 1450 & 1490T
http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045072079076045071065051053085/Default.aspx
RAM Mount Locking Knob for 1 inch Socket Arm with 0.25 inch-20 Brass Thread
http://www.gpscity.com/search/q=ram-knob3l
-custom arm for the mount, you can choose short arm (2.25'' or standard 3'' long)
http://www.gpscity.com/parts-b-size
Total I spend around $70 for the system mount on GV250.
Kymco Grand Vista 250cc 2009
GY6 150cc 2008
kbro
Re: GPS mount for GV250
« Reply #1 on: June 15, 2011, 02:28:32 PM »
was the ram reservoir cover a generic or custom version?  The brake reservoir on the GV looks tiny compared to the clutch/brake reservoir on my BMW K1200LT.  I have the same set up on my motorcycle and I'm guessing the adjustable mounting holes on the cover would work on the smaller GV reservoir.  How does it look?  can you post a pic?
thanks
2009 Kymco GV 250
2003 BMW K1200LT
2007 Honda ST1300 (sold)
2006 Kymco People 250 (sold)
2002 BMW R1150RT (sold)
1989 BMW K100LT (sold, but still in the family)
mcg305
« Reply #2 on: August 30, 2011, 12:34:28 AM »
Great post; thank you!
I am going to try it on a 2010 500.
Regards,
Brian
2010 Xciting 500Ri ABS
2006 People 250 (sold)
allenquach
« Reply #3 on: September 03, 2011, 10:10:50 PM »
thanks
It's a generic one. Adjustable mounting hole. At first I saw the picture on the Ram website and check for pdf instruction for size (I guessed adjustable hole). Immerse yourself into those links to custom your mounting like on your bike.
GY6 150cc 2008
mcg305
« Reply #4 on: September 04, 2011, 02:45:05 AM »
Ram mount works great. Reservoir cover is adjustable & fits 2010 xc500. I used cover plate (zrmb346),  double socket arm 3” (zrmb201u), diamond shape with 1” ball (zrmb238), and finally a garmin holder matched to my gps. 4-pieces ... $45 from gpsZone.
bashby47
Re: can you use the cell phone charger plug for the GPS?
« Reply #5 on: November 15, 2011, 10:12:37 AM »
I was wondering if the cell phone charlger plug can be used to run the GPS system on a Grand Vista 250?
bunker buster
« Reply #6 on: November 18, 2011, 08:24:43 PM »
Yes it can, have done it. But the GPS wire should be long enough
scootit
« Reply #7 on: November 22, 2011, 08:42:02 PM »
I just use the suction part that came with my GPS. I ride all the time and never had any troubles. I just hook the GPS onto the mount , run the wire under the seat and plug it in.  These GPS are cheap the day after Thanksgiving so if you lose it, so what.
WMM
