Author Topic: Kymco People S 50cc  (Read 7223 times)
GM6969
Re: Kymco People S 50cc
« Reply #15 on: June 23, 2011, 05:58:57 PM »
Nice to hear :D
Stefan
Can you help me then...
Weights: ?
Clutch springs: ?
Driven face spring/Torgue: ?
Malossi belt ( after Clutch change ) ?
Main yet in carb: ?
Boss drive I have, 38/20mm and on yours...
Iridium gives more Horsepower :)
Video, in russian, but frst on is normal, second is iridium.
Just look the difference :D
asources
« Reply #16 on: June 23, 2011, 07:24:14 PM »
Good day,
It is all stock , the only mod i did it is with the cdi box ... original it was running at 60KM/H ... with the mod 72/75km/h
I plan on trying some mod to get more speed at red light ... and not loosing speed uphill...
Not sure will try yours ... because i was thinlink you were running faster than mine with these specs...
But already order malossi vario ...
Stefan
GM6969
« Reply #17 on: June 24, 2011, 07:45:22 AM »
Good day,
Stefan
All in stock, good :D any idea what can be relevant tuning parts, as I dont have stock parts, but as I understand after so much testing, stock is the best for this scooter.
GM6969
« Reply #18 on: June 24, 2011, 08:51:17 AM »
Hello to All,
made some videos, maybe you can answer :)
Clutch, belt, boss drive...
With Leo Vince ;)
But yes, still would like to know stock = tuning parts description, relevant stock to tuning.
GM6969
« Reply #19 on: June 27, 2011, 04:50:53 PM »
Thanks to one Smart person found best spec ever.
5.1 Gramme rollers, yellow clutch spring and original torque spring and jet #85.
GM6969
« Reply #20 on: June 28, 2011, 05:43:57 PM »
Hi to All,
if you thinking to buy Leo Vince excsaust... do not buy it!
For Kymco People it does not give anything. Only Chopper sound :D
ianmac
« Reply #21 on: July 01, 2011, 05:50:20 PM »
Thanks for the advice.... thats a lot of coin to be spending for a different sound!
ianmac
« Reply #22 on: July 01, 2011, 05:51:44 PM »
This is just the info I was looking for.... Do you know the spec of the yellow spring?
1000k 1500k or 2000k?
Cant wait to get my #85 main jet now.... #88 is too much.
GM6969
« Reply #23 on: July 02, 2011, 11:38:16 AM »
Hi yes, if you will look Malossi springs...your question is little bit unclear :)
But I will try to answer.
If you asking about 3 springs in the clutch...then its like middle power/acceleration, soft is white, middle is yellow and strongest malossi is black.
If you are asking about the torque sping, big one, then malossi has classified: White is 1000rpm, yellow is 1500rpm and red is 2000rpm.
I used original torque sping, any chinese stock spring will fit ;) and 3 yellow malossi springs in the clutch + 5gramm rolls, original drive belt, boss drive is 37mm ( original I think is 38? ). And jet is 84 not 85, this seems to be best really.
Unrestricted cdi + iridium spark plug.
Now I ordered Dr Pulley sliding rolls 5gramms let see what happen, if I also add/change this....where those rolls are fitted :D dont know in english.
In this case I can say that my weight is 110kg :) and scooter runs 65-70km on flat road, down the hill :D its like A bike :D
« Last Edit: July 02, 2011, 11:46:13 AM by GM6969 »
ianmac
« Reply #24 on: July 08, 2011, 12:22:55 PM »
If you were most happy with 5g rollers you should have went with 6g sliders.
Always go 1g heavier with sliders.
GM6969
« Reply #25 on: July 10, 2011, 11:07:29 PM »
Finally got Dr Pulley 5g. rolls...
Perfect, what else can I say.
Variator is finally set as it should, unrestricted CDI, Iridium spark plug and slider rolls.
Now its more like 125cc
Tested it: hill is 45degrees, before 35km/h max, now 45 without a problem. Very fast takeover, end speed is about 65km/h with my 110kg body on it.
If there is any questions about Kymco People S 50cc, I think finally I know all :D
sidthesloth
  • Kymco ZX50
« Reply #26 on: July 10, 2011, 11:29:41 PM »
45km/h is still pretty slow, even for going up a hill.
GM6969
« Reply #27 on: July 11, 2011, 12:25:15 AM »
This is a four stroke model, so its not so bad.
Or if you have suggestions for the 50cc, best perfomance :)
ianmac
« Reply #28 on: July 11, 2011, 03:37:22 PM »
Agreed....
And trust me, you will never know it all, there is way too much involved in modding your scoot.
