Author Topic: Jet size???  (Read 1266 times)
bmcafee
Jet size???
« on: May 22, 2011, 07:26:28 PM »
I have a agility that I have upgraded the engine to 81cc and I am not sure what size jet that I need to be running basically I swapped out the air box for the cone filter and am still running the stock exhaust pipe. I keep hearing terrible things happen if you let yourelf run lean. Thanks guys!
Bradders2125
  • 2010 Agility 50
Re: Jet size???
« Reply #1 on: May 22, 2011, 11:17:21 PM »
I'm no expert, but, from what I've read you should check the spark plug to see if your running lean or not. You can find picture guides online for what to look for. You can buy a jet pack with various sizes. You can then change jet, go for a ride, check the spark plug and then change to another jet if necessary until you find the correct size needed.
Hope this helps, theres plenty of people on here who will be able to say if I'm wrong or not, and they will be able to give more info.
Brads
bmcafee
Re: Jet size???
« Reply #2 on: May 23, 2011, 02:40:19 AM »
thanks i will look into the jet pack.
