Author Topic: bet and win 250 dashboard backlight  (Read 31459 times)
gazibarev
« on: May 30, 2011, 04:20:04 PM »
Please help. Dashboard backlight on my 250 bet and win is dead. How to fix it??
gazibarev
Re: bet and win 250 dashboard backlight
« Reply #1 on: June 01, 2011, 08:36:42 PM »
up
coldice
« Reply #2 on: June 11, 2011, 01:21:34 PM »
how did you repair it????
gazibarev
« Reply #3 on: June 19, 2011, 10:28:16 AM »
I still have not fix it :-[ :-[ :-[
NigelB
« Reply #4 on: May 23, 2012, 12:59:01 AM »
Mine died just after a year of purchase (2002). Never got it fixed yet and every year in winter I say to myself : I gotta fix this...
Did you manage to get yours done?
NigelB
« Reply #5 on: July 16, 2012, 12:33:40 AM »
OK, if anybody's interested, the dashboard backlight is NOT fixable.
It appears that the "backlight" is actually an illumination strip - i guess it is some or other type of flourescence activated by electricity.
Getting the unit apart is another beast, which presented a nice challenge. The front cover is glued tightly shut so cannot be lifted out. So I drilled it out, using a small bit and about 300 holes (just a guess). After that it was plain sailing. I took everything apart except the needle because i was afraid that once the needle comes off it might not fit properly again. The strip was then almost accessible - just had to cut it so that I could slip it out around the needle.
My plan is to use 5 or 6 hi-bright green LED replacements. Now that the illumination strip is out I can get the LEDS right up against the perspex reflector lens - at least I'll be able to see my speedo now at night! The front cover will be reglued / resealed into place with some good silicone.
cheers
« Reply #6 on: July 16, 2012, 12:40:12 AM »
Nice work.
Rudolf
  • Born to be wild!!!
    • Facebook
« Reply #7 on: July 19, 2012, 10:36:36 AM »
I've measured the two terminals leading to the illumination element using a multimeter and found out that there isn't any voltage going in. I believe there is a problem with the electronics powering the lighting element and i'm thinking to bypass the original electronics and create a separate circuit to power that element. Just need to find out at what voltage is the backlight working.
« Reply #8 on: July 20, 2012, 12:00:13 AM »
Check for power into, and out of the switch. This should be a 12V circuit unless it was LED lit.
Rudolf
    • Facebook
« Reply #9 on: August 11, 2012, 09:00:42 PM »
I've checked and tried to light up the element by providing electricity separately. I also found out that there aren't any LED's. There are two contacts feeding the illuminator. I also found out that the backlight is a electroluminescent backlight or EL Backlight Sheet.
« Last Edit: August 11, 2012, 09:22:22 PM by Rudolf »
Rudolf
    • Facebook
« Reply #10 on: August 11, 2012, 09:24:12 PM »
It glows a phosphorous green when on. I only have an issue because the backlight sometimes it turns on and sometimes it switches off randomly.
« Reply #11 on: August 13, 2012, 01:27:44 AM »
I'd drill some holes, and add led's
Rudolf
    • Facebook
« Reply #12 on: August 13, 2012, 06:33:20 AM »
In the PCB or the white plastic fame under the LCD? (Grand Dink/Grand Vista 250)
« Last Edit: August 13, 2012, 06:56:31 AM by Rudolf »
Rudolf
    • Facebook
« Reply #13 on: August 13, 2012, 06:51:38 AM »
The contacts of the backlight. (Grand Dink/Grand Vista 250)
« Last Edit: August 13, 2012, 06:56:15 AM by Rudolf »
Rudolf
    • Facebook
« Reply #14 on: August 13, 2012, 06:52:31 AM »
The circuitry of the dashboard. (Grand Dink/Grand Vista 250)
I believe that the little black box "Epicenter E5-652Z" is the DC/AC inverter for the backlight and is faulty.
I read that it runs on  5V DC +10% and puts out around 80V AC +15% @ 600Hz +20%.
« Last Edit: August 13, 2012, 07:10:30 AM by Rudolf »
