Author Topic: speedo stuck at 0mph  (Read 954 times)
ScottNicol
« on: May 30, 2011, 06:52:49 PM »
hi all!
my speedo on my agility 50 has been stuck at 0mph since yesterday. was riding home from work when i first noticed it, but my mileage isn't moving either. i undid the bolt holding the cable in place and fiddled with it, but no luck, still doesn't move... :(
anyone have any adivce?
sidthesloth
  • Kymco ZX50
Re: speedo stuck at 0mph
« Reply #1 on: May 30, 2011, 10:08:26 PM »
Slide the inner cable out to see if it is broken. Have you noticed any unusual noises recently?
woodcutter
« Reply #2 on: May 31, 2011, 12:03:55 AM »
I had simmilar problem, except mine was stuck at 20 km/h
My dealer solved the problem by re-routing cable around steering column(moved it a little bit right when looked in front view)
'cause it was tight and pressing needle against tacho.
You need to remove complete front mask with head light to do this job
If this doesn't solve your problem, other cause might be
broken cable or dead speedometer
« Last Edit: May 31, 2011, 04:06:15 AM by woodcutter »
ScottNicol
« Reply #3 on: July 27, 2011, 07:45:21 PM »
Yeah, the cable has broken at the end of the wheel, where it joins to the fork-style thing at the end... Anyone know where I can get a new one in the UK?
ollieboi555
  • Agility 50
« Reply #4 on: July 29, 2011, 10:38:18 PM »
Mines a bit like this ive had a new clock fitted and the spedo sometimes reads in mph and sometimes in km its still restricted and its quite funny when it says im doing 50mph even tho im actually doing 31 or 32mph
