Author Topic: Brake Light Wire Colors - Givi Case  (Read 1290 times)
oreilly907
« on: May 31, 2011, 03:36:07 AM »
I almost never found this info. I just thought it might keep someone else from pulling their hair out. When installing a Givi brake light conversion, you are looking for a green w/ yellow stripe (+) and solid green (-) wire. The only wiring diagram I could find was so blurry that I couldn't make out the colors. I hope this helps.
bilyum
  • Super 8 150
Re: Brake Light Wire Colors - Givi Case
« Reply #1 on: January 30, 2012, 06:46:17 PM »
I think the green with stripe is brake lamp ,and solid green is negative conductor  the Brown is tail lamp and lic plate lamp
Later
bilyum
