Author Topic: Front brakes 09 people s 250  (Read 1297 times)
bandit
« on: June 01, 2011, 03:28:08 AM »
Every time I make a right turn the front brakes squeal. I have taken both calibers off and the pads, rotors and everything looks fine. ??? I only have 600 miles on it. The brakes work fine and the front wheel turns easily. Has anybody else had this problem?
« Last Edit: June 01, 2011, 03:30:41 AM by bandit »
bandit
Re: Front brakes 09 people s 250
« Reply #1 on: June 03, 2011, 02:28:24 AM »
Found the problem. The brake rotor was loose. A torque wrench and loctite solved the problem.
