Author Topic: big build!!!some advice or tips would help  (Read 8590 times)
Pattyboi33
Re: big build!!!some advice or tips would help
« Reply #30 on: June 11, 2011, 02:48:34 AM »
I'm probly going to reuse the old bolts but get the washers that are cut an like spring loaded .. I feel like the biggest retard I can't even think of the name of these WOW . but when u tighten them up they squish shut an the use some locktight on the bolts
thebatman
« Reply #31 on: June 11, 2011, 02:53:54 AM »
lock washer.....lmao
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
« Reply #32 on: June 11, 2011, 03:24:08 AM »
Don't use lock washers, you won't get a seal.
Pattyboi33
« Reply #33 on: June 11, 2011, 02:06:35 PM »
LMAO serious brain fart but ok cool good thing u told me that I don't really want an air leak do u know what the torque specs are for the head an jug bolts
sidthesloth
  • Kymco ZX50
« Reply #34 on: June 11, 2011, 08:07:49 PM »
1.5 kg/m or 15 nm. I think that is about 10 lb/ft
Pattyboi33
« Reply #35 on: June 11, 2011, 11:19:13 PM »
Ok sweet thanks did your crank come with the bearings allready pressed on the crank shaft? Man I can't wait for this crank to come in the mail uhhhh !!!!
sidthesloth
  • Kymco ZX50
« Reply #36 on: June 12, 2011, 12:11:32 AM »
Nope, they were in little plastic bags.
Pattyboi33
« Reply #37 on: June 12, 2011, 01:50:03 PM »
Did u have a hard time getting them on ?
sidthesloth
  • Kymco ZX50
« Reply #38 on: June 13, 2011, 09:00:13 PM »
If you can get a hold of the right tools it would be easy, I don't have the right tools so it was a bit tricky.
Oil pump blanking plug:
http://www.exportstrength.com/product_info.php?products_id=621
Pattyboi33
« Reply #39 on: June 14, 2011, 12:46:51 AM »
How did. Do it because I have a press but I don't wanna press the bearings up agenst the crank to far is there a space u need inbetween ?
thebatman
« Reply #40 on: June 18, 2011, 01:16:54 AM »
DON'T press them. You will warp the crank... I DO SPEAK FROM EXPERIANCE THERE. :'(
Use the hot cold method... the 1st time is tricky as sid said before.. A good heat gun comes in handy.. :D ;)
"THE BAT"MAN...
Says:
Pattyboi33
« Reply #41 on: June 18, 2011, 02:09:19 AM »
I heated the bearings in the oven at 350 an then the crank in the freezer worked perfict
thebatman
« Reply #42 on: June 18, 2011, 02:39:27 AM »
awesome....... ;D
"THE BAT"MAN...
Says:
Pattyboi33
« Reply #43 on: June 18, 2011, 03:45:22 AM »
I was so amped I didn't think it was going to work that well ! Well tomorrow is the big day 90cc topend 44.4 mm stroker crank 28mm oko powerjet carb sweet intake nice cone filter technegas pipe I can't wait to listen to this thing purr like a little kitten !!! >:)
thebatman
« Reply #44 on: June 18, 2011, 11:00:58 AM »
90cc top end?
You have the next r pipe or a rs2? the next r prolly won't be good enough for what your planning....
"THE BAT"MAN...
Says:
