Author Topic: big build!!!some advice or tips would help  (Read 8586 times)
thebatman
Re: big build!!!some advice or tips would help
« Reply #60 on: June 22, 2011, 11:17:55 PM »
http://www.treatland.tv/OKO-24mm-carburetor-p/oko-24mm-carburetor-clear.htm
Here is the link to the place i have been getting my jets....
Pretty fast on shipping from them also, of course they sell "kits", i dont think they sell single jets like S.A does
"THE BAT"MAN...
Says:
Pattyboi33
« Reply #61 on: June 23, 2011, 12:59:40 PM »
Ok so I bought a pack of ten main jets an a pack of ten slow jets I'm going to put a 170 main an see where to go from there idk why but I have this funny feeling that I'm going to need a monster size jet
thebatman
« Reply #62 on: June 24, 2011, 12:00:27 AM »
Good deal.....
 :o WOW... A 170?    Where about's are you residing?   i'm thinking that'll be WAY rich
Oh yeah, btw, have you done a leak down test?...to test for any leaking gaskets... I had a blown head gasket before and it leaned the piss out of my baby....(soapy water works too...lol)
"THE BAT"MAN...
Says:
Pattyboi33
« Reply #63 on: June 24, 2011, 09:26:16 AM »
It's just a wild guess an I'm thinking so because I'm mixing 32/1 so the oil is taking up octain in the fuel and I removed the oil pump . But why do the leak down test ? There all brand new gaskets
sidthesloth
  • Kymco ZX50
« Reply #64 on: June 24, 2011, 10:31:45 AM »
You would be surprised at how many leaks you might have. I have heard that the oko inlet and reed cage can be bad for leaks.
thebatman
« Reply #65 on: June 24, 2011, 11:13:29 AM »
I been running right around 40:1.....
Yeah, sids right.. I know i've had several leaks around the intake/reed cage myself... ANd a word of caution/advice..... Keep an eye on all bolts and nuts also, mine have worked loose/.... Guess that's why somebody invented loctite ::)..
Carb cleaner is good to use also but of course the scoot needs to run and w/o the fan shroud you cant let it run long.... I woulda thought a 130 would be plenty big enough, but of course i'm still learning... ;)
You can make a tester pretty cheap, if you search for the cheaper prices but around $20 i have in mine. It's not fancy but it works
"THE BAT"MAN...
Says:
Pattyboi33
« Reply #66 on: June 26, 2011, 04:17:50 AM »
I used thread locker on every bolt lol an I used a sealant on the gaskets for the reeds when i did it to
sidthesloth
  • Kymco ZX50
« Reply #67 on: June 26, 2011, 04:58:53 AM »
I don't think threadlock will be too good for retorque.
Pattyboi33
« Reply #68 on: June 27, 2011, 03:14:21 AM »
Very true good thing I bought a new tap an die set ^_^ so the jets came in any suggest would be cool I get new mains an pjs
Pattyboi33
« Reply #69 on: June 27, 2011, 10:11:57 PM »
I'm going to do a leak down test I'm holding I don't have any leaks I honestly don't wanna tear this thing down to far again
Pattyboi33
« Reply #70 on: June 28, 2011, 10:13:11 PM »
So I did the leak test an I'm good now I went to play with some jets an I was revving it an it jus lost spark idk what happen
Pattyboi33
« Reply #71 on: July 05, 2011, 03:55:55 AM »
It was my coil now I have the tzr50 cdi
