Did you miss your
activation email
Correct tire PSI for Yager G 200i
Topic: Correct tire PSI for Yager G 200i (Read 715 times)
ScooterWolf
June 04, 2011, 12:55:48 PM »
I seem to be getting different info on the correct PSI for my Yager. The manual says app 28 PSI, with 35 as the max. The info on the side of the tires says 40 PSI. Anyone know what the correct level should be?
-Wolf
J-7
Newbie
Re: Correct tire PSI for Yager G 200i
June 04, 2011, 01:02:05 PM »
Depends on rider weight and comfort. I usually start in between the manual listings and the tire listings, and go higher or lower depending on if it feels too hard, or too soft. I never go below or above one or the other.
old geezer
Sr. Member
June 04, 2011, 01:07:57 PM »
The PSI stated on the tire is for maximum pressure. That means you should not exceed that. The PSI in the book is what you want and what the factory recommends for average riding, load and performance from the tires.
Last Edit: June 04, 2011, 01:10:08 PM by scooterdude
ScooterWolf
Reply #3 on:
June 04, 2011, 02:05:16 PM »
Thanks everyone. I've lowered it to around 30 PSI. I'm about to ride into Philly from NJ to see how the ride goes.
Thanks again,
-Wolf
Back
