Will need to check at the weekend when I do my clutch, if scooter assassins every deliver my 1000rpm spring. The old stock ramp plate was solid, had no play at all, would not slide up and down on crank, could hardly get it off. Had to spend ages teasing it off by waggling it, almost gave up and was going to cut it off, but I got it in the end without doing that. My new variator fits snug on the boss and has no extra looseness, seems ok, sure its my ramp plate now. Will try your advice of a shim or washer behind it if it feels loose when I tighten my variator up, if I can get my fingers in to check. Its the actual centre hole that to me seems maybe a half mm or so too large for the crank, maybe its meant to be like that tho? Going to drill my stock hole a touch bigger and try that at the weekend anyway.
I got my scoot 2nd hand, done about 11,000km then I changed to the variator I posted, sure the stock one had been the original so had lasted 3yrs exactly when I got it. Was a bit worn and grooved but still worked ok. The stock plate on my old stock variator has plastic bushes too, do the more expensive ones have brass then?
Dont see much point in splashing out now for a good malossi etc unless I was getting a good 3-4yrs out of it at least, will just stick to the cheapo ones prob for now.
Surely you can just buy new bushes for a few quid instead of having to get a whole new variator?
