G'day All, just a small update, on Tuesday night after work I had a mongrel time trying to start the scooter, kickstart was jamming, (battery was not strong enough to start it). On wednesday, I opened the cvt and cleaned out the dust from the kickstart mechanism, this time I have tried a little light machine oil for lubing the kickstart gear shaft, (which seems to be good so far). While I was there I found some small balls in the case which I suspected to be the ramp plate slide bushes. Sure enough, they were gone, nothing left at all this time. So, after putting in the last set I had I went and ordered more from Scooter Assassins, then replaced the 1,500 torque spring with the 2,000 just to see what it is like, I thought the 8 gram sliders were a touch too heavy so this should work quite well. Since I had the clutch apart I decided to install the new clutch I got from Scooter Assassins a couple of months ago. I fitted the 2,000 fly springs that came with the clutch and put it all together. When going to work I found that the stall speed was much higher than with the older fly springs, which were also 2,000 rated. Well, by the time I got to work, 8 kilometres, there were some problems, clutch was staying engaged. I thought the springs might be broken. Thursday I stripped it again to find the springs were not broken, but one of the clutch arms was broken and the spring from that was grinding between the clutch bell and cvt cover. I will try to put up a pic of the clutch if I can. I have emailed Scooter Assassins, but am yet to hear back from them.
