Author Topic: carb  (Read 948 times)
carb
« on: June 06, 2011, 10:30:23 AM »
is it ok to use seal a gasket on a carb.
sidthesloth
  • Kymco ZX50
Re: carb
« Reply #1 on: June 06, 2011, 11:46:07 AM »
I am not familiar with that product, but if it states as being suitable for use with fuel, it would be ok.
Portland Steve
Re: carb
« Reply #2 on: June 08, 2011, 08:02:36 PM »
If it is the liquid stuff, I hate it.
Try to get the actual gasket material if you can.
Re: carb
« Reply #3 on: June 08, 2011, 09:06:02 PM »
to late im already trying it.so far so good.nock on wood hope it hold up.I only needed a little in one spot on the carb.most of it staed on the outside.
streido
Re: carb
« Reply #4 on: June 08, 2011, 09:27:30 PM »
Are all agility 50 stock carbs the same? Does anyone know if you can buy a new rubber gasket for the bottom end? When I changed my jet I saw mine was a bit distorted and I had to use gasket sealer to secure it in place when I put it back on, was going to put a new one if if you can buy them?
If you can buy them what carb is it on a stock agility 50 from jan 2008?
Chaos is my co-pilot.
Re: carb
« Reply #5 on: June 08, 2011, 10:53:10 PM »
Im useing a seal from off a gy6 carb some run the same but look close at theam some are a slight diff.
macocoy
  • Sting/yup 50 2 stroke(2009)
Re: carb
« Reply #6 on: June 08, 2011, 11:37:44 PM »
Useing?theam?
Scooters r big boys toys-
Tecnigas next r,malossi variator,1000 clutch torque spring,Uni open air,
Re: carb
« Reply #7 on: June 09, 2011, 12:53:27 PM »
Useing?theam?
lol ya I know but it works.its been in the scoot for a week now and no leaks seal pretty good.
had to put seal a gasket with in in one spot that was tore because it cam of a old scoot.
