Did you miss your
activation email
Scooters - 50cc
Super 9
ummm i might have a water pump issue
Topic: ummm i might have a water pump issue (Read 868 times)
mudfreek
Full Member
June 09, 2011, 09:46:53 PM »
hey guys srry its me again i just might have an issue with my water pump i just started hearing a slight chatter on the water pump side of my engine how do u know when its about to fail?
ehh brakes are for sissies
thebatman
The Bat lives on... like the fkn Energizer Bunny
Re: ummm i might have a water pump issue
June 10, 2011, 06:11:56 PM »
Yeah, the waterpump bearing may be going out on you.. You'll have to drain the coolant and remove the small cover and inspect for play,etc...
"THE BAT"MAN...
Says:
mudfreek
Full Member
June 10, 2011, 10:53:53 PM »
thanks
thebatman
Reply #3 on:
June 11, 2011, 01:08:41 AM »
You may want to check that before you get stuck out somewhere one day....
MAybe just the impeller blade or something is loose or the bearing is getting worn.
Hopefully it'll be something else simple....
"THE BAT"MAN...
Says:
mudfreek
Full Member
Reply #4 on:
June 11, 2011, 10:40:44 AM »
i acualy called the shop where i bought my bike and they are going to waranty it
Back
