Author Topic: hard to start  (Read 1071 times)
fshfindr
hard to start
« on: June 11, 2011, 04:32:49 PM »
Coming home from the gym yesterday, my Yager would not start.  I flipped the side stand (which I had not used) up and down a few times and it started.  At home I looked under to find the switch but could not find it.  Any one know where the switch is and if it is accessable?  Or any other ideas?  It is only 3 days old.  It has been fine since, starting each time.  Thanks.
Rich L.
Richard L. in Bellmawr
ScooterWolf
Re: hard to start
« Reply #1 on: June 13, 2011, 06:52:06 PM »
I'm not sure if it is accessible. I think there's a sensor that will stop the engine from running/starting if the side stand is down. Generally I find if it doesn't start it means I forgot to switch the start/cut off switch, of didn't squeeze the brake. There could be something off with the side-stand sensor.
-Wolf
