Last nite I went to buy a torque wrench, but that’s a diff story. This AM I started to check nuts. I did not get far because the nut on the left side of the front wheel was totally loose. I could spin it with my fingers. The wheel did not come off so I guess I’m lucky. I only know the correct torques from the manual, so if anyone knows the correct torque for the front wheel nut, please let me know.
In fact I need to know the correct torque for all the nuts if anyone has them. The next question is about the same problem. I tightened the 19 mm nut on the left side but the right side nut, which is smaller, did not move on the screw. I do not know how many threads are in the right side nut which is a cap nut. Any info will be appreciated.
Thanks,
Rich
