Author Topic: American Kymco Super 8 50cc 4 stroke  (Read 14044 times)
Maxblast
Re: American Kymco Super 8 50cc 4 stroke
« Reply #45 on: July 31, 2011, 09:27:49 AM »
It is hardly possible to put a nice permanent rpm meter on this scooter so I bought a cheap meter on Ebay, just for testing.
I have also no idea about the rpm of this scooter so I need to check this first.
« Last Edit: August 01, 2011, 07:08:14 AM by Maxblast »
spidrgr
« Reply #46 on: August 09, 2011, 02:27:17 PM »
 I have a 2009 people s 50 4t, as in 4 stroke.  When new, it topped out at an indicated 57-58 kph. Completed the breaking in period and got my first oil change at the dealer. While it was in, I got in contact with Kymco reps via internet. They got in contact with my dealer which proceeded to derestrict the CDI. Result: 68-70 kph. Still, I believe there is still some restriction but I dont care, that speed is good for city trafic. After that, changed the stock rollers. They were 7.0 g., even though the owners manual cites 8.0 g. So, after trying some new 7.0 g rollers, I got some 6.0g rollers. Better acceleration somewhat better up hills, but still, not enough power going up. I mean, pretty steep stuff. I live in a mountain. Did the GPS thing, got 63 kph for an indicated 68-69 kph on the counter. It translates as 39 mph. There was no restrictor on the variator. I tried removing the restrictor in the air filter, but the engine cant take it with the stock jet. It just starves for fuel as there is to much air coming in. I think  the last remaining thing left to be done is getting a .85 main jet in the thing and opening up the air intake. As I said, I dont need more speed, just more climbing power. Funny thing though, acceleration seems adequate, never seems to slow down traffic, as a matter of fact, usually the contrary. But the minute I encounter a slight incline, it slows down to 50-55 kph, slower on steeper ones. I'm just lazy about the carb and my wife, which is much lighter than I am ( I'm 200 lbs) doesnt seem to complain. My real bike is a Suzuki DL 650. But still, scooters are so much fun around town....
All this might help you, since the mechanicals on the People s50 4t are about the same as your Super 8 4T. I wouldn't change the variator, I believe It will not give more performance, maybe smoother performance, but I find it acceptable on the Kymco stock one. What I havent figured out is if changing the big pring in the rear part of the trans mission will allow the engine to raise its revs when in need of more power going up hills. As it is right now, it just seems to settle at a constant rpm and just slow down to about 35 kph on the steepest of hills and just stay there until the incline levels off, then the needle on the speedo just sweeps up again.
All in all, maybe not the most performing little machine, but up to now, a very reliable one and easy to drive. Also very cheap on gas.
streido
« Reply #47 on: August 09, 2011, 03:20:09 PM »
That big spring is called the torque spring. Try a 1000rpm one instead and it should help uphills. I used to drop to 20-25mph on my agility 50 up some steep hills, after I fitted a 1000rpm torque I now do 30-35 up the same hills. I def gained at least 5-7mph uphill, and it changes up gear better when I hit the hills if req for more power.
Chaos is my co-pilot.
spidrgr
« Reply #48 on: August 09, 2011, 05:23:45 PM »
Thanks Streido!
But does it keep its top speed on the flat ground? Or is it now slower?
streido
« Reply #49 on: August 09, 2011, 05:33:34 PM »
Still get 45-48mph or around 75km/h showing on the speedo on flats. I maybe lost 1-2 mph but im not 100% sure yet, maybe just my imagination and wind. Going to keep an eye on it.
