Did you miss your
activation email
Technical | How To
super fever zx50 / will not run unless choked / vacum leak??
Topic: super fever zx50 / will not run unless choked / vacum leak?? (Read 1031 times)
jnova402
Newbie
June 15, 2011, 05:25:31 PM »
50cc super fever that will not run unless I partially block the carb(choking it).Carb is spotless inside/has fresh plug/gas and oil .Help!
thebatman
The Bat lives on... like the fkn Energizer Bunny
Re: super fever zx50 / will not run unless choked / vacum leak??
June 19, 2011, 12:47:23 AM »
That could be jetting..mix screw setting..
Could you give us more info?.....jets installed, screw settings?
"THE BAT"MAN...
Says:
Back
