Author Topic: Won`t start  (Read 1548 times)
cooler70
Won`t start
« on: June 16, 2011, 12:11:26 PM »
My scooter wont start after taking the cylinder head off. At first the valve timing was off, but i fixed that. Now the timing is spot on and still wont fire up. Im out of ideas. I hope that that people in this forum can help me.
Re: Won`t start
« Reply #1 on: June 16, 2011, 12:44:09 PM »
what cap did you sit the valves at. it should be .04 a hair smaller is ok.
cooler70
Re: Won`t start
« Reply #2 on: June 16, 2011, 04:45:17 PM »
I didn´t touch those gaps.
streido
Re: Won`t start
« Reply #3 on: June 16, 2011, 09:20:38 PM »
Take its turning over, just not starting? Got a spark at the plug?
Chaos is my co-pilot.
Re: Won`t start
« Reply #4 on: June 17, 2011, 12:09:04 AM »
if you reset the timeing your valeves might need to be recaped now seting the time may have throwen things off.
hungryrussian
  • Kymco Agility 50 "Sonic"
Re: Won`t start
« Reply #5 on: June 17, 2011, 02:49:47 AM »
i agree i set my valves immediately before i rebuilt my motor and when i put it all back together it wouldn't start because my intake valve had gotten so tight it wasn't closing completely therefor no compression and exhaust coming out of my intake... also are you certain gas is getting to your compression chamber? could need a carb cleaning and vacuum line check.. just throwing some ideas out there. good luck
'08 Agility 50, 72cc BBK, Naraku HS High Speed Variator, some clutch tweaking, UNI filter with homemade cold air setup, Leo Vince Handmade Titan exhaust, lots of random upgrades i'll never be able to remember.. the look on people's faces when i put a knee down through a curve makes it all worthwhile
cooler70
Re: Won`t start
« Reply #6 on: June 17, 2011, 01:07:42 PM »
I think i  have found the problem. The intake valve is bent. I`ll let you guys know if i get the problem solved. Thank you all for your help ;)
