Author Topic: 50 mxer carb setup  (Read 2172 times)
50mxer_Des
50 mxer carb setup
« on: June 16, 2011, 02:11:03 PM »
Hi All,
I'm new here and hope someone can point me in the right direction!
We have bought our son an old 50 mxer and I need some help setting the carb up properly.
The carb is a Keihin "KT" with auto choke. There are two adjuster screws on the left-hand side of the carb body which I'm guessing are the mixture and tickover settings.
Is there a "standard" setting for these i.e. "screw in fully then back off 3 turns" ...
We're having a real headache getting it to run properly and I want to get everything back to "factory" before trying anything else!
If there's some info that would help, just shout  :)
Thanks to all,
Des
GSY PETE
Re: 50 mxer carb setup
« Reply #1 on: June 16, 2011, 03:41:01 PM »
Hi
If you go on Google search
type in
kymco mxer 50 service manual
there is a list of free downloads
hop this helps
Pete
50mxer_Des
« Reply #2 on: June 16, 2011, 03:48:05 PM »
Hi Pete,
Thanks - Great minds think alike!
Just done that and for future ref by other 50Mxer's it's:
1. "Air Mix Screw" (fwd most screw) screw in fully (don't over tighten) then out 2 turns.
2. Adjust idle speed with "Throttle Stop Screw" (other screw)
3. Adjust Air Mix Screw for max revs.
Sure I'll have other questions but for now, it's Ciao!
Des
