Author Topic: Modified my like 50 2t  (Read 1174 times)
Like50ninja
« on: June 16, 2011, 07:09:49 PM »
I just installed an arreche 19mm carb with a 95 main jet and a 30 pilot jet
I derestricted the stock air box and I also installed a techni gas exhaust with the expansion chamber and silencer, I have a 70cc malossi cylinder kit
My scooter runs hot which i think means it's running lean and when it idles it seems to be idling at to high of a rpm, also during the first part of acceleration it feels like it's stuttering and then it kicks in and goes but sounds a lot louder/higher pitched than it did when I had the stock stuff on
When I was installing the arreche i felt like the throttle cable might not have been long enough cause it didn't seem like the needle was going as far down as it should
Any thought on how I can get it to run smoother??
