Author Topic: Xenon HID on S 250  (Read 1630 times)
eugenec
Xenon HID on S 250
« on: June 18, 2011, 01:34:19 PM »
Not too impressed with the stock 35W lamps in my People S250, I replaced one of them with a 35W HID dual beam Xenon bulb and it works quite well. The H4 HID bulb matches the original bulb perfectly in terms of the light patterns. I did have to replace the Kymco headlight relays with mechanical ones so they can handle the initial current surge needed by the HID ballast. The whole conversion cost about $40 and is well worth every penny of it.
« Last Edit: June 19, 2011, 04:18:55 AM by eugenec »
scosgt
Re: Xenon HID on S 250
« Reply #1 on: June 18, 2011, 10:39:27 PM »
The headlights in my S200 are AC, not DC, so how did you get the HID to work?
eugenec
« Reply #2 on: June 18, 2011, 11:44:06 PM »
You can rectify the AC to your headlight to DC and use it to turn on/off the relay. Connect another wire from the relay to your battery to supply the DC power to the HID.
scosgt
« Reply #3 on: June 19, 2011, 12:55:21 AM »
Could you be more specific? What kind of rectifier did you use, where did you buy it, how did you connect it?
eugenec
« Reply #4 on: June 19, 2011, 04:15:17 AM »
I did not need to rectify my power source. People S 250 uses DC for headlights.  In your case, you will need to use diodes or bridge rectifier to turn AC into DC. Since the relay coil does not draw much current, pretty much any rectifiers will do. The HID will use the DC current from the battery so the wire from the relay switch to the battery should not be too thin.
Do you have a multimeter? If you have not used a multimeter before, I suggest you get someone who are familiar with basic electronics to help you. I may be able to draw you a wiring diagram if you want.
« Last Edit: June 19, 2011, 04:17:53 AM by eugenec »
