Author Topic: 2 stroke scooter blowing white exhaust smoke  (Read 27098 times)
Fab has a scooter
« on: June 20, 2011, 03:18:33 PM »
 hi everyone! Im new to the site and have to sayin theres a wealth of info here  :)
Well, I have a 2002 Kymco People that I adore. I made a moved from fort lauderdale to Tampa and here im not able to ride her as much bc of all the highways around me. Anyway so she was sitting for about 5 months and I pulled the carb cleaned her up real nice. She had a rough start but eventually turned on. To my surprise she was blowing a lot of pure white smoke. I was told to put a bit of seafoam but that didnt stop the smoke at all! I put some fresh fuel and shes still smokin smh. She runs great but the smoke is embarrassing and it smells like something is burning. The exhaust pipe has a bit of burnt oil in the end.
Ive had her for a year and a half and I've changed the transmission oil once and regular oil changes (without cleaning the screen bc I just found out where it was).
Today im headed to get some oil to replace the old and was told octane boost would eliminate the smoke.
So any recommendations?
How many quarts do you guys used just in case im putting too much?
How do you clean the oil screen?
Thanks again!
Fab   ???
juice
Re: 2 stroke scooter blowing white exhaust smoke
« Reply #1 on: June 20, 2011, 06:24:38 PM »
Im confused . You say you changed the transmission oil , ok . The only other oil is the 2 stroke oil , I only add 2 stroke as needed . Why would you change it ?
sidthesloth
  • Kymco ZX50
« Reply #2 on: June 20, 2011, 06:59:06 PM »
Sounds like you are getting too much oil through, is the pump stuck open?
Fab has a scooter
« Reply #3 on: June 20, 2011, 09:41:46 PM »
Ok so this is going to sound weird but long story short  I changed the gear oil when I first got the scooter. The next time I thought I was changing the oil and got confused. But anyway no engine oil ever in the gears. I know I did  that right lol. As im researching I realized that I dont have to change the engine oil just added when its low. before I left fort lauderdale I accidentally put 4 stroke oil instead of 2 so I drained it directly from the oil container.   So today I did what I previously wrote,  replaced the gear oil, bought a new spark plug and oxane booster but didnt put that in yet.
Now something new.. The tip of the spark plug which is usually a metal peice was stuck in the wire and for the life of me I couldnt get it out. So now I hVe to buy a new wire before I know if any of this worked  :-\
 My old spark plug was burnt like ashes and it also had oil in the spark plug socket. That cant be good. :: sigh::
streido
« Reply #4 on: June 20, 2011, 09:57:31 PM »
When you fix the spark plug etc, give it a good run on new fuel and it may just clear itself out. Could be from transporting it and leaving it sitting the oil has seeped thro the seals. Agood run may burn it all off and it may be fine.
Strange your spark plug was in such a state tho ???
Chaos is my co-pilot.
Fab has a scooter
« Reply #5 on: June 21, 2011, 12:54:36 AM »
It is weird unless its supposed to be that way. I dont see how bc my new spark plug has the medal peice attached. ??? Weird... and I was trying to pull it out of the spark cap but it wouldn't move at all. I tried pulling it with pliers and everything. Thankfully I found they sell the cap alone. Just  have to order and started her up. Ill definitely update
Fab has a scooter
« Reply #6 on: June 21, 2011, 01:08:12 AM »
Sidethesloth: I honestly dont know how to tell if the pump is stuck open. How can I check that?
sidthesloth
  • Kymco ZX50
« Reply #7 on: June 21, 2011, 01:24:17 AM »
have a look in the service manual, there is a link to download one in the general section. If you put engine oil in there, that could be the source of your smoke. Have a look at the oil pump and see if the cable operates it correctly, the pump control lever should rotate as you turn the throttle. There should be a pointer on the pump lever and one on the bracket, these pointers should line up together when the throttle is fully open.
Fab has a scooter
« Reply #8 on: July 02, 2011, 10:30:39 PM »
Ok update I bought a new cap, spark plug is installed and now it blows blue smoke a lot!  I also feel like it lost a bit of power as well. Im reading its the valves or it could be running too rich? What do you guys think? I thought this would do it  :-\
sidthesloth
  • Kymco ZX50
« Reply #9 on: July 02, 2011, 10:50:44 PM »
Do you have the correct oil in the oil tank?
Fab has a scooter
« Reply #10 on: July 11, 2011, 08:39:10 PM »
yeah i have the right oil. I think its oil slipping through the valves. I just dont know how to see if thats it or how to fix it.
juice
« Reply #11 on: July 11, 2011, 09:08:56 PM »
Once again I think we are confusing 2 stroke and 4 stroke . Your 2 stroke scooter burns a mixture of gas and oil , that is how it operates and it will have smoke in the exhaust from the oil combusting . What valves are you speaking of ? Maybe this will help :
www.deepscience.com/articles/engines.html
« Last Edit: July 11, 2011, 09:19:52 PM by juice »
Fab has a scooter
« Reply #12 on: July 26, 2011, 01:49:02 PM »
See i dobt know that much about scooters mechanically, but im a very handy person. My kymco people 50 is a 2 stroke scooter. The blue smoke coming out  of the exhaust means its burning oil. Leaky valves is what im being told it might be. If its not leaky valves what could it be thats causing it to smoke so much? It never smoked until it sat for so many months.
Fab has a scooter
« Reply #13 on: July 26, 2011, 02:22:31 PM »
I read about adjusting the oil injection it may be putting too much oil in the fuel tank while its mixing. Im looking at the manual and it doesnt tell me how to adjust it.  I also read about cheap aauto parts oil. I always use auto parts oil and it never smoked. Do you guys think it could have vaught up to me? Could it be running too lean? My old spark pkug was while full of carbon deposits would i adjust that o. The car?
I know i ask a lot of questions and i appreciate all of your help. Too broke to take it to a shop.
juice
« Reply #14 on: July 26, 2011, 03:15:58 PM »
Fab , your 2 stroke scooter is SUPPOSED TO HAVE SOME SMOKE EMITTING FROM THE EXHAUST . Your 2 stroke scooter does not have valves for oil to leak past . You need to use 2 stroke oil in it , full synthetic 2 stroke oil will not smoke as badly because it has a higher burn tempreture . You also need to quit listening to whoever has been giving you incorrect information about your 2 stroke (not 4 stroke scooter) . Good luck . P.S. Any additives should go into the gas tank , never in the 2 stroke oil tank .
« Last Edit: July 26, 2011, 04:23:39 PM by juice »
