Author Topic: 2 stroke scooter blowing white exhaust smoke  (Read 27097 times)
spidrgr
Re: 2 stroke scooter blowing white exhaust smoke
« Reply #15 on: July 26, 2011, 05:44:43 PM »
I agree with juice. No valves, at least regular valves on 2 strokes that will cause smoke. Some 2 strokes have reed valves and i've seen some older seventies Kawasakis which had rotary valves. But none of those valves caused smoking other than normal oil consumption which is a normal 2 stroke occurence. Just get good 2 stroke oil. Preferably, one formulated for a 2 stroke oil injection system.
juice
« Reply #16 on: July 26, 2011, 09:35:50 PM »
I have been thinking about your people 50 today and I belive it might be best for you to drain out all of the gasoline and oil from your gas tank and 2 stroke oil tank and lines and start fresh with new gas and a good 2 stroke oil . Don't mix the oil and gas in the gas tank . put only gas in the gas tank and only 2 stroke oil in the oil tank . Then run at least one tank of gas through and see if it returns to normal . I hope so . Good luck .
« Last Edit: July 26, 2011, 09:47:42 PM by juice »
Fab has a scooter
« Reply #17 on: August 02, 2011, 02:27:00 PM »
Thanks a lot juice! Guess i have to get the non smoking oil then. It just never smoked blue smoke before so i was concerned and it really doesnt look good.
juice
« Reply #18 on: August 28, 2011, 01:07:12 PM »
Does Fab still have a scooter ?
