Did you miss your
activation email
Scooters - 125 to 300
People 150
Loose Headlight
Topic: Loose Headlight (Read 1994 times)
Scootaloot
Full Member
Loose Headlight
November 08, 2008, 03:04:42 AM »
Was cleaning my scooter today and found the headlight was just sitting inside the housing and doesn't seem to be attached to any mount but seems to only be attached by the electrical plug. Is that normal? or due I need to take it apart? Thanks for any comments. Scooter hit 1500 KM today and is running well since all the initial problems
sw19
Newbie
Re: Loose Headlight
November 12, 2008, 01:22:14 PM »
Open the headset and see where it came loose. Also look underneath, there's an opening in the plastic piece for the headlight adjusting (aiming) bolt.
-Stan
Scootaloot
Full Member
Re: Loose Headlight
November 13, 2008, 02:25:22 AM »
Thanks sw19. I did already figure the adjustment screw/bolt fell out but if you know what size it is that would help a bunch! Is it a screw/washer or a bolt?
Back
