Author Topic: fork oil  (Read 2215 times)
jimd
fork oil
« on: June 29, 2011, 11:57:25 AM »
One of the major complaints about the connie I had before my x500 was its mushy front end. One solution was to put a heavier fork oil in  . I was wondering if that could be done on the x500? Has anyone tried this? Would it work?  ???
JustWantToRide
Re: fork oil
« Reply #1 on: August 05, 2011, 09:39:42 PM »
Using a heavier fork oil in a non-adjustable fork is a good way to increase the damping on any fork.  I haven't opened up the forks - but if you want to add some preload to the springs you can probably find a washer that will fit on top of the springs and inside the cap.   If you find som air fork caps that fit - then let us know.  That's a cheap and effective upgrade.
2009 Xciting 500Ri
   52mpg so far
axy
Re: fork oil
« Reply #2 on: August 06, 2011, 11:12:35 AM »
Yes, but only marginally.
Scooters have so bad suspension and handling that such intervention cannot compensate.
Not worth the hassle, IMO.
Kymco Agility 125 2008
Veniamy
Re: fork oil
« Reply #3 on: February 05, 2012, 02:13:36 PM »
how much oil goes in when replacing and what grade, I cannot find that information nowhere.
Veniamy
Re: fork oil
« Reply #4 on: February 06, 2012, 04:39:40 PM »
Thanks Munks, if i understood correctly he used 0.4l of 30W fork oil per shock absorber,  i don't know if the same grade should be used in XC500 because XC500 is heavier than XC250  but that is a start...
drifter
  • Twist n' Go Power!!!
Re: fork oil
« Reply #5 on: February 07, 2012, 06:59:22 AM »
think it's more than 100ml per shock. there is a mark or something on the shock, you will fill it up to that mark i gues. that's what we did on mine and rides great
"it's more fun to ride a slow bike fast than to ride a fast bike slow!"
