Did you miss your
activation email
Technical | How To
leaking transmission oil
Topic: leaking transmission oil (Read 2060 times)
marioG
Sr. Member
July 03, 2011, 06:39:13 PM »
Still is leaking after 5000 km....i put too much oil into transmission...
now is bleeding....everytime...did something brake...
help?
FUBAR is an acronym that commonly means "f***ed up beyond all recognition/any repair".
juice
Re: leaking transmission oil
July 03, 2011, 07:42:16 PM »
When I overfilled my transmission (people 50) it blew out the seal and every time I rode it the rear wheel and tire got covered in oil . I had it replaced now its ok . Good luck .
July 04, 2011, 11:59:12 AM »
some scoots have offer flows for the extra to come out at some dont you need to find out if yours does. if it does you are all good my other scoot has a over flow on it my kymco does not. just take the train bolt off and tip scoot to the side and let some drain out.
marioG
Sr. Member
Reply #3 on:
July 04, 2011, 06:26:07 PM »
where is the seal?
i cant believe, i put 7dcl of oil------2l came off...
juice
Reply #4 on:
July 04, 2011, 06:42:29 PM »
91255 91255-LDC8-E10 OIL SEAL 27*42*7 $3.95
marioG
Sr. Member
Reply #5 on:
July 04, 2011, 07:30:18 PM »
its coming out to airbox, throu rubber conection...11221
Last Edit: July 04, 2011, 07:32:22 PM by marioG
old geezer
Sr. Member
Reply #6 on:
July 04, 2011, 09:50:35 PM »
Its vented and will over flow to the air box when overfilled. Just get the excess out of there and clean the air box up.
marioG
Sr. Member
Reply #7 on:
July 05, 2011, 05:01:11 AM »
maybe is too thick....
which oil?
i think i used 80w.....
old geezer
Sr. Member
Reply #8 on:
July 05, 2011, 12:03:31 PM »
Quote from: marioG on July 05, 2011, 05:01:11 AM
which oil?
No, it uses 80W90 gear oil.
I use castrol Hypoy C 80W90 gear oil. It states on the label, maximum gear protection for motorcycle, ATV, and scooter transmissions.
Last Edit: July 05, 2011, 12:07:15 PM by scooterdude
sidthesloth
Kymco ZX50
Reply #9 on:
July 05, 2011, 12:18:21 PM »
If you put too much oil in, even though it is not overflowing, when you run the scooter it can froth up and be forced out the breather.
marioG
Sr. Member
Reply #10 on:
July 06, 2011, 01:50:39 AM »
im gonna warm it up and bleed out all oil till last drop....
then inject amount only by spec for this scoot....
tnx
Back
