Yep, welcome! And yes, CVT tuning -- that would include variator, clutch, and, if necessary, belt would probably be the route to go. There are a thousand nuances in all of that but some basics are:
Lighter weights in the variator give pepier low end acceleration, but perhaps cut into your top end. Heavier weights do the opposite.
Stiffer clutch springs (on the shoes) make the clutch grab at a higher rpm, therefore give a more thrilling take off from a dead stop. One must be willing to twist the throttle aggressively to take advantage of that.
A stiffer torque spring (that's the big one behind the clutch) will hold the motor in a higher rpm band in relation to the rear wheel longer. That's usually a help to "peaky" two stroke engines.
Belt length may need to be taken into consideration when doing some of these if either pulley is held in a significantly more narrow state. You can get away with stock length belt if your mods are relatively mild.
Whole aftermarket variators and clutches are available for some models, some are nice and some not so nice. You may still wind up tuning them even so. Ask around here and elsewhere about the potential quality of anything you might be shopping for.
My first mod was variator weights. I went a gram heavier to try and get more top end and mileage out of my Xciting 500. Since then, I've bought a Dr. Pulley clutch which is nice and tuneable.
Remember there will be a learning experience as you go and of course, there are exceptions to every rule.
![Grin ;D](https://www.kymcoforum.com/Smileys/default/grin.gif)
Welcome rperry!
