Hi,
My P50 is having some issues and I'm not too mechanically engine savvy so layman's terms preferred! It started this weekend and got to the point where it's hardly running at all, even on flat ground.
Going uphill, it coughs and eventually dies. On flat ground, it does this to a certain extent, unless I'm only giving it a little bit of gas but once I go passed that amount, it sounds like it's going to die again.
Any ideas on what could be the problem - I'm going to either try to fix it myself if it's an easy fix or at least be educated when I go to get it fixed.
Thank you!!
