Author Topic: Kickstand  (Read 6025 times)
Corp_T
Kickstand
« on: July 06, 2011, 11:20:12 PM »
Ok, I just bought my 2009 Agility 125cc on Saturday and it has a center kickstand. Is it also supposed to have the side kickstand as well? It's kinda a hassle to use the center stand when I'm just going to be off it for 20 seconds and where I'll be parking at work they have plates on the ground for kickstands.
scootchesco
Re: Kickstand
« Reply #1 on: July 07, 2011, 12:00:50 AM »
I have a 2009 Agility 125 as well. It has both a center stand and a regular kick stand. Yours should have both.
Red Horn
Re: Kickstand
« Reply #2 on: July 07, 2011, 10:13:21 PM »
In-N-Out = Side Stand
Center if away more than few minutes or ground solidity is suspect. It is also more stable if scoot was to get "bumped".
Corp_T
Re: Kickstand
« Reply #3 on: July 08, 2011, 09:39:38 AM »
I just hate putting down the center stand so I can throw the trash away and be back on it 2 seconds later. But yeah, I contacted the dealer and it turns out the kickstand was "sitting in the back" not sure what that means since I think it generally comes installed on the scooter. Either way they're shipping it to me. Thanks for the heads up that it's standard.
JENNY
Re: Kickstand
« Reply #4 on: July 13, 2011, 01:49:16 PM »
All the scooters come stock with a center and side stand.  You could order the oem one thru me.
jenny
tnt cycles
717-453-7265
marioG
Re: Kickstand
« Reply #5 on: July 13, 2011, 06:10:42 PM »
FUBAR is an acronym that commonly means "f***ed up beyond all recognition/any repair".
dwnthehatch
Re: Kickstand
« Reply #6 on: July 13, 2011, 07:15:39 PM »
Mine didn't have a sidestand either. What is needed? I assume the side stand, bolts and springs. I'm wondering if it's worth the cost.
Corp_T
Re: Kickstand
« Reply #7 on: July 14, 2011, 12:21:59 AM »
that's all it was. A stand, a spring, and a bolt. Really easy to install, would have been easier if I used a pair of pliers to pull the spring instead of re-purposing tools.
JENNY
dwnthehatch
Re: Kickstand
« Reply #9 on: July 20, 2011, 06:24:50 PM »
Thanks!
dwnthehatch
Re: Kickstand
« Reply #10 on: August 17, 2011, 03:44:45 PM »
I got all of my parts in:
Stand Assy Side
Spring comp side stand
Screw side stand pivot
Plate spring stopper
I can't figure out how to install the spring stopper.  Can someone take a picture of the underside of the sidestand assembly?
I see no place for the bracket.
Also, my stand folds up as soon as I take it off of the stand unlike the picture above.
Thanks!
« Last Edit: August 17, 2011, 04:52:32 PM by dwnthehatch »
axy
Re: Kickstand
« Reply #11 on: August 17, 2011, 07:38:00 PM »
Stand Assy Side
Thanks!
On A125 and some other Kymcos I had (Cobra Cross 50), side stand behaves like yours.
What is shown on MarioG's picture is not typical.
OTOH, on my P250S, side stands remains extended as on this picture.
Kymco Agility 125 2008
dwnthehatch
Re: Kickstand
« Reply #12 on: August 17, 2011, 09:10:20 PM »
Thanks. I figured out the problem. I drove 50 miles to the nearest Kymco dealership. They have 3 Agilities in stock. I took a look at each one.
1. The side stand pivot screw in the schematic is 1/2" longer than the ones on the showroom floor. It it protrudes through the sidestand and causes the spring to kink. I corrected it by grinding the screw to the correct size.
2. The spring(s) in the parts schematic are incorrect.  The schematic shows a large spring with a smaller spring inside of it.  I received the double spring and it is barely strong enough to keep the side stand up.  It folds back down when hitting a bump. The ones on the showroom floor all had a much thicker gold single spring that look like the centerstand spring. I'm not sure if they are the same or not.
3. The plate spring stopper in the schematic cannot be found on any of the scooters at the dealership. I checked both 50cc and 125cc scooters. I'm not sure why it's even in the schematic.
So it looks like I will be ordering another centerstand spring to see if it will hold up the sidestand. Can anyone measure it against their sidestand screw to see if they are the same?
This time I will order from the dealership. I'm a little irritated that I was charged $19.77 to ship a package that was in a clearly reused box that only cost them $5.35 to ship. If I know the shipping charges were going to be that high I would have bought locally. Live and learn.
old geezer
Re: Kickstand
« Reply #13 on: August 20, 2011, 07:14:52 PM »
BTW, is Jenny the one that overcharged you on the shipping??
