Author Topic: Standard weight of sliders in variator 2009 super 8 150  (Read 4795 times)
rperry
  • Can you see me now
« on: July 07, 2011, 03:09:16 PM »
Hi help how much do factory stock sliders or rollers weigh on 2009 Kymco Super 8 150.
The answer seems to be 12g anybody disagree ?.
I went ahead and put in Dr Pullet Sliders, Dr Pulley 12 g Slider weights.
Clutch arm springs, 3 yellow and Main Clutch big spring yellow.
Let you know how it turns out.
Boy the first thing i notice is the smoothness of the clutch engaging. It feels silky smooth.
I will report on the variator when i drive cross town tomorrow. A good upgrade for the money so far ?.
« Last Edit: July 13, 2011, 11:55:52 PM by rperry »
bucky639
Re: Standard weight of sliders in variator 2009 super 8 150
« Reply #1 on: July 07, 2011, 04:19:21 PM »
I don't know.
Take 'em out and weigh 'em then let us know.
I am glopezz05!
Kevin
« Reply #2 on: July 25, 2011, 05:29:33 PM »
Hey rperry,
Any update on the performance? Better top speed or acceleration?
Did you weigh your original rollers?
Thanks!
--kevin
'09 Kymco Super 8 150 Blue 'n Yellow - first two wheeled street machine, of many to come...  :D
old mod
« Reply #3 on: July 25, 2011, 09:05:13 PM »
I know the standard weight for the Agility city r16 (kL25B engine, Super 8 125 is KL25, Super 8 150 is KL30) are 13g, i imagine they are the same.
rperry
« Reply #4 on: July 25, 2011, 09:09:38 PM »
Hi Kevin
Replaced with yellow, the Clutch Main Spring. Three Clutch Arm Springs.
3 Sliders and Weights in variator. 12 gram was what i took out and 12 gram was what i replaced. I used DR Pulley.
Top Speed is 65 on the speedo on the scooter. I was in 55 mph traffic and catching them easily.
rperry
« Reply #5 on: July 25, 2011, 09:15:58 PM »
Hi the weights just don't cost that much, so i went with the standard 12 gram. I feel it smoothed everything up. Take off mid range and pickup. I was happy with the results. I am mostly in 45 mph traffic, occasionally into 55 mph traffic.
If i wanted a faster machine i would have bought a bigger sized scooter. A Super 8 150 is good value for the money.
rperry
« Reply #6 on: July 25, 2011, 09:23:24 PM »
Hi sorry i almost forgot ?. There seems to be some belt slap at certain times of acceleration. I took the cover off and watched. The belt where it feeds out of the variator, on the bottom slaps a bit. I guess it is the bigger clutch spring making it a bit harder to open the clutch pulley up. So i think the belt is a little loose on the outfeed from the variator.
Any thoughts on the matter ?.
old mod
« Reply #7 on: July 25, 2011, 09:44:47 PM »
It's quite normal for the belt to slap around, when it's not under tension. If you're not happy with it you could fit a kevlar belt but the size is critical, a bit small and it will snap!
