Author Topic: Exhaust Gasket  (Read 1179 times)
Kenho21
Exhaust Gasket
« on: July 09, 2011, 10:18:11 PM »
Is there any advantage/disadvantage to using my stock exhaust gasket with my aftermarket exhaust? The one that came with the exhaust has been taken off a put back on a couple times and is a little deformed, could I still use it or are these supposed to be one time use things?
It's one of those aluminum or steel (I'm not sure) ones.
sidthesloth
  • Kymco ZX50
Re: Exhaust Gasket
« Reply #1 on: July 09, 2011, 10:51:31 PM »
I think they are generally a single use item, though you can reuse them as long as they seal.
streido
Re: Exhaust Gasket
« Reply #2 on: July 13, 2011, 02:10:23 PM »
Put a little motor exhaust sealer on the surfaces when you refit them. As long as its not leaking it should be fine.
Chaos is my co-pilot.
Kenho21
Re: Exhaust Gasket
« Reply #3 on: July 14, 2011, 04:37:01 PM »
What about using the stock ceramic or plastic (not sure) with my performance steel exhaust?
