Author Topic: 2009 Agility 50 Fuel Gauge Issue  (Read 1639 times)
meekman
« on: July 11, 2011, 01:34:54 AM »
Hey, I have a 2009 Agility 50 and for some reason the fuel gauge is not working, but the other gauges are working fine. I took off the handlebar cover and attempted to tighten the screws that I thought were holding in the fuel gauge wires, but this didn't fix it. If there is an easy way to troubleshoot this, any advice would help. I don't really want to spend a lot of money to try and fix this since it is not a huge issue.
sidthesloth
  • Kymco ZX50
Re: 2009 Agility 50 Fuel Gauge Issue
« Reply #1 on: July 11, 2011, 02:17:24 AM »
Try checking that the float in the tank is not stuck, alsn check that the wire connector has not become unplugged.
meekman
« Reply #2 on: July 12, 2011, 12:20:30 AM »
I checked the float and it is not stuck, but which wire connector are you referring to? I checked the ones directly under the fuel gauge and it appears they are all connected, but I don't know if there is another connector I need to check as well. If anyone could tell me which wire exactly to check that would be helpful. Thanks!
sidthesloth
  • Kymco ZX50
« Reply #3 on: July 12, 2011, 01:48:15 AM »
Start with the one at the tank and then follow the wires through.
« Last Edit: July 12, 2011, 06:35:47 AM by sidthesloth »
« Reply #4 on: July 12, 2011, 03:41:58 AM »
check your fuse that is next to the battery.
