Did you miss your
activation email
Scooters - 125 to 300
Super 8 150
Tire pressures in psi
Topic: Tire pressures in psi (Read 12597 times)
mrpackerguy
Jr. Member
July 13, 2011, 11:59:59 PM »
When I do the conversion (via google) of Kymco's tire pressure recommendations (found on the sticker 'neath the spedometer) I come out with 21.3 psi for the front and 23.9 psi for the rear. Does this sound right?
Only reason I ask is because the front was 40psi and the rear was 35psi.
For what it's worth, I also discovered my odometer over-reports by 0.1 mile and my spedometer checked out at 3mph slow (27mph scooter) at 30mph actual and 3mph slow (37mph scooter) at 40mph actual.
2007 Silver Agility 50
2009 Green Super 8 150
juice
Re: Tire pressures in psi
July 14, 2011, 12:35:13 AM »
Your conversion numbers sound a little low to me , but you should experiment to find what is most comfortable for you . I run 32psi in my people 50 .
JENNY
Jr. Member
July 14, 2011, 05:23:31 PM »
32 - 36psi will work...look at the tire sidewall it will have it on there
slugrocket rob
Jr. Member
Reply #3 on:
July 14, 2011, 06:21:51 PM »
yup, play around with what works for your riding style and weight. I usually run a little over 20 psi front and a little under 30 psi back. Also keep an eye on how your tire's wear, that will give you more info to work with.
mrpackerguy
Jr. Member
Reply #4 on:
July 14, 2011, 07:03:06 PM »
All good advice.
Huntsville, Alabama
Reply #5 on:
July 15, 2011, 03:04:40 PM »
When I did the conversion to PSI I came out with 29 PSI front and 32 - 36 PSI rear depending on solo rider or passenger. This has worked fine for me. The dealer had it at around 35 front and 40 rear. It rides much better at 29 & 33 PSI.
Back
