Author Topic: Rear Shocks  (Read 1457 times)
rperry
  • Can you see me now
Rear Shocks
« on: July 18, 2011, 06:31:43 PM »
Hi am i the only one who thinks the rear shocks are too stiff. They are on the lowest setting for spring tension, but seem so stiff. Does anyone have any ideas. I weigh 196 ?.
« Last Edit: July 18, 2011, 08:46:05 PM by rperry »
juice
Re: Rear Shocks
« Reply #1 on: July 18, 2011, 07:21:10 PM »
How much air do you have in your rear tire ?
rperry
Re: Rear Shocks
« Reply #2 on: July 18, 2011, 08:44:55 PM »
The stated amount, 29 psi ?. When you sit on the scooter, the shocks don't move at all ?.
juice
Re: Rear Shocks
« Reply #3 on: July 18, 2011, 08:56:34 PM »
Sounds like you have faux shocks .
rperry
Re: Rear Shocks
« Reply #4 on: July 18, 2011, 09:06:59 PM »
Faux may be the brand, Can you get a new spring for the outside ?.
JENNY
Re: Rear Shocks
« Reply #5 on: July 20, 2011, 06:37:58 PM »
You can usually purchase just the springs and replace them.  Check on the web under the shock name and see if they offer replacement springs.
Portland Steve
Re: Rear Shocks
« Reply #6 on: July 20, 2011, 11:28:31 PM »
I agree that the rear shocks are "too stiff" as you say.
If I had an extra $250 I would invest in some after market shocks that are more adjustable.
However, if I had the money, I would probably be riding a bigger scooter or motorcycle.
You can always do my $5 seat pad mod, which helps a bit.
rperry
Re: Rear Shocks
« Reply #7 on: July 21, 2011, 11:58:55 AM »
Went out and tried them again. When i lay across the rack on the scooter they do not give, the tire flattens some. They seem way too stiff a spring. I guess Kymco is making sure it will carry two. I am thinking of looking at a Cycle Salvage, will need to measure everything up. I agree to buy new shocks would defeat the purpose of buying a used scooter in the first place.
