Author Topic: clutch problem...?  (Read 1150 times)
GM6969
clutch problem...?
« on: July 21, 2011, 09:34:52 PM »
Hello to all,
can you suggest give me ideas, how to understand if clutch is broken?
Seems like a have this problem, but not 100% sure.
Thank you in advance.
Gallo
streido
Re: clutch problem...?
« Reply #1 on: July 23, 2011, 11:19:55 PM »
Probably best to 1st open up the cvt cover and take the bell housing off to remove the clutch assembly and have a look at it. Make sure you have some depth left on the clutch pads and check no springs are broken or loose. Also give a clean out if its dirty inside.
If the clutch looks ok it may just be dirt in it and a good clean can fix it.
Chaos is my co-pilot.
GM6969
« Reply #2 on: July 25, 2011, 10:59:16 AM »
yes, good idea to clean up, will look on the weekend.
Thank you1
streido
« Reply #3 on: July 25, 2011, 01:31:36 PM »
My clutch was not fully dis-engaging when I stopped at lights etc a while ago. I took it apart and cleaned it up and it worked fine after that. Hopefully it may work for you too.
GM6969
« Reply #4 on: July 27, 2011, 09:09:29 PM »
Thank you, I will try to open all the vario side tomorrow.
