Author Topic: other drive belts.  (Read 5599 times)
Re: other drive belts.
« Reply #30 on: August 11, 2011, 01:15:43 AM »
if your belt wont go all the way down on the clutch you may need a new main clutch spring
streido
« Reply #31 on: August 11, 2011, 07:28:19 AM »
Nah, the springs good. I put in a new clutch 2-3 months ago so changed all fly springs and put in new torque too then. Old belt goes all the way down fine.
Did you get your belt yet?
Chaos is my co-pilot.
mikrron
  • at least outstanding !
« Reply #32 on: August 11, 2011, 10:18:29 AM »
after some kms the belt runs much better now! the take off is smoother (the belt sticks better on the parts) and the top speed is again around 75km/h and 80km/h downhill. What i like now is that no matter how hard i accelerate the transmision doesen`t vibrate anymore. I can still hear a whistle in my transmision but it sounds nice and i don`t think it`s something bad.
CHECK OUT THIS BELT SPECS:
-the kymco manual says the OEM belt 17.5mm wide but not the lenght of it
-i measured the old OEM belt and it`s ~746 (maybe i have a bad tool or the belt streched over time)
so malossi 743 is a bit wide but the lenght is ok (maybe it`s designed for the white spring that omes with malossi multivar)
i can`t imagine how a 729 belt even with the right wide, cand give you full variator surface rising.
next thing i`ll do if i raise money is o buy malossi multivar with 4.5-5g rollers
sorry for my writing mistakes .. i`m only human
streido
« Reply #33 on: August 11, 2011, 10:26:59 AM »
729mm long is right for the agility. I have a race variator fitted and I checked it rides all the way to the top edge.
Think the multivar is slightly larger so a longer belt would work on that, I dont have a multivar tho. Def goes to top of variator tho, I checked.
« Reply #34 on: August 11, 2011, 12:07:37 PM »
 ya I got my new belt on but I stell need new rollers picking theam up tonight. it rides ok but just not fully there with the old rolllers stell in it.
